Sample rate issue with "save as" option
#1
The edited audio file, select Save As, the sample rate and bit rate of the pop-up menu are not the sample rate and bit rate settings of the currently edited audio(img01)。
Other software will change the sampling rate and bit rate according to the sampling rate and bit rate of the currently edited audio file
Thank you for the efforts of the soundop team, many problems in use have been solved, thank you very much!
#2
(02-16-2022, 05:30 PM)18216239004 Wrote: The edited audio file, select Save As, the sample rate and bit rate of the pop-up menu are not the sample rate and bit rate settings of the currently edited audio(img01)。
Thanks for the report.
We have fixed the problem and released a new version. Please check it out.
#3
The same problem also exists when the audio file is saved directly after editing
#4
(02-18-2022, 05:23 PM)18216239004 Wrote: The same problem also exists when the audio file is saved directly after editing
The mp3 format only supports specific sample rates. So when you save to  mp3, the sample rate may not be the same as that of current audio data.
