Threads: 61
(01-26-2026, 07:41 AM)Mogutronics Wrote: Good evening,
I'm joining this thread because I'm testing Soundop after having used many others. I've always been happy with Audition, but I'm having problems with some VSTs, and it's becoming increasingly heavy and slow.
I also use Ocenaudio, iZotope, etc., but I really like this project, and I think I'll purchase a permanent license to replace Audition.
I have two requests that are similar to those made by Ivellios: simple 0°-180° phase inversion in the mixspace with a button in the file window (next to the “stereo-mono” button, for example) and the ability to normalize to standard levels other than EBU and even arbitrary levels. It would also be useful to be able to normalize in batch mode by analyzing a playlist or an entire album rather than individual files, and to be able to use VSTs in batch mode.
Thank you for this “young” software, which is already very good and promising!
Thank you for your suggestion and your kind words.
For phase inversion in Mixspace, you can use the Channel Mixer effect by adding it to the track FX rack. We are not sure it is necessary to add a dedicated button for phase inversion, as most DAWs do not offer this feature. However, we will consider adding it if you believe it would be useful.
Soundop already supports normalizing audio to an arbitrary loudness level. Additionally, you can normalize audio files and process audio files with VST plugins using the batch processor. Custom processors can be created in the audio file editor and applied within the batch processor.
If you have further suggestions, please don’t hesitate to tell us.
Threads: 0
Many thanks!
When talking about batch normalizer, i was asking for a "album" normalizer, so it's not single track to process but the entire list as a single album and keep relative levels as previously decided.
Thank for phase inversion with channel mixer, i didn't realize.
As a VST i would like to share a link of Flipper. Free, lightweight, no latency, just enable and invert phase when and where you want.
https://www.refusesoftware.com/flipper
Regards
Threads: 61
(01-31-2026, 04:17 AM)Mogutronics Wrote: Many thanks!
Regards
Thanks for sharing.
Regarding album normalization, analyzing all files in an album to adjust their levels conflicts with the batch processor, since the batch processor handles each file independently.
As an alternative, you can append the files in an album into a single file, which will create markers for each track. You can also set an optional gap when appending the files. After normalizing the combined file to the target loudness, you can export the audio within the markers to separate files with a single command.
If you have any other questions or need additional help, we’re here to assist.
Threads: 0
YOU ARE SO GREAT!!! keep developing Soundop, it deserves to be a new standard in audio editing and small DAWs!
I bought it for lifetime. Thanks
Threads: 61
(02-06-2026, 06:19 AM)Mogutronics Wrote: YOU ARE SO GREAT!!! keep developing Soundop, it deserves to be a new standard in audio editing and small DAWs!
Thank you!
