I love working with Soundop. Since I switched from Adobe Audition to Soundop I'm absolutely amazed by how fast and flawlessly your software works.
Over the years I used a lot of audio editors, including Audition, Acoustica, Izotope's editor, etc. Soundop works the best for me but there's one feature it lacks, namely the ability to edit multiple files at once.
I know there's the function of batch processing but that's not what I'm talking about.
In other editors I can create some effects rack, click 'Apply', it starts processing my file (or some fragment of a file that's currently opened) and then I can go to some other file and start playing or processing it. In Soundop, however, once I apply the filters, when this 'Please wait...' window pops up I can't do anything else, I have to wait until processing finishes and only then I can start editing other files.
Another thing that I find very useful and that I would like to have in Soundop is automatic phase rotation. From what I observed, it's not very common in audio editors, I only found something like this in Izotope's editor and Acoustica, and only in Acoustica this tool seems to work properly. Automatic phase rotation works in a way that reduces 'ups' and 'downs' in the waveform to eliminate issues with adjusting the loudness of the audio.
As I said, this feature seems to be not very commonly implemented in DAWs, in fact, I don't even know if there's a VST plugin capable of doing this.
(12-25-2023, 08:57 AM)Ivellios Wrote: [ -> ]I love working with Soundop. Since I switched from Adobe Audition to Soundop I'm absolutely amazed by how fast and flawlessly your software works.
Thank you very much for your kind words and suggestions.
We will try to improve the workflow and add the new tool in future versions.
I second both functions. Simultaneous processing/editing of multiple files is crucial for me, and it's the only thing preventing me from using/buying Soundop.
We have released Soundop version 2.1, which added an option to process audio in non-blocking mode. Please check it out.
attachment=352]
attachment=353]
attachment=354]
First of all, I would like to thank you for releasing SDSetup_x64 (2.1.0.1). My fellow voice artist friends and I are truly amazed to see that, keeping pace with the times, other DAWs are utilizing AI technology, so why should Soundop lag behind?
I am hopeful that a “How to Remix Short Music Like Adobe Audition” option will be added soon. This feature would greatly assist content creators like us in creating quick and simple music beds. Thank you once again!
(12-14-2024, 07:56 AM)pavelgazi Wrote: [ -> ]First of all, I would like to thank you for releasing SDSetup_x64 (2.1.0.1). My fellow voice artist friends and I are truly amazed to see that, keeping pace with the times, other DAWs are utilizing AI technology, so why should Soundop lag behind?
Thank you for your suggestion. We will prioritize this feature in our plans.
Non-blocking mode works as expected when editing and exporting single files, however, when I export a multitrack session it goes away and I need for export to finish before I switch to something else (using Soundop v. 2.2.2.0)
https://ibb.co/rK0819XC
(01-10-2026, 10:20 AM)Ivellios Wrote: [ -> ]Non-blocking mode works as expected when editing and exporting single files, however, when I export a multitrack session it goes away and I need for export to finish before I switch to something else (using Soundop v. 2.2.2.0)
Thanks for your feedback.
At present, Soundop does not offer a non-blocking mode in the multitrack editor, as we are not certain it is needed for exporting, which is performed less frequently.
If you believe this feature would be beneficial, please let us know. We will consider adding non-blocking mode to the multitrack editor in future updates based on user interest.
Good evening,
I'm joining this thread because I'm testing Soundop after having used many others. I've always been happy with Audition, but I'm having problems with some VSTs, and it's becoming increasingly heavy and slow.
I also use Ocenaudio, iZotope, etc., but I really like this project, and I think I'll purchase a permanent license to replace Audition.
I have two requests that are similar to those made by Ivellios: simple 0°-180° phase inversion in the mixspace with a button in the file window (next to the “stereo-mono” button, for example) and the ability to normalize to standard levels other than EBU and even arbitrary levels. It would also be useful to be able to normalize in batch mode by analyzing a playlist or an entire album rather than individual files, and to be able to use VSTs in batch mode.
Thank you for this “young” software, which is already very good and promising!
