dark mode menu bar
#1
Currently, Soundop's pull-down menus are displayed in gray with using the option settings "Use dark theme for menu", which is easy on the eyes, but menu-bar such as "File, Edit, Transport, Tools..." use the standard Windows scheme of black text on a white background. (even if the system is in dark mode.) Therefore, as a future perspective, I would be happy if it were possible to set this to a complete dark mode menu-bar with white text on a black background.
#2
(07-09-2026, 01:15 AM)takecha Wrote: Currently, Soundop's pull-down menus are displayed in gray with using the option settings "Use dark theme for menu", which is easy on the eyes, but menu-bar such as "File, Edit, Transport, Tools..." use the standard Windows scheme of black text on a white background. (even if the system is in dark mode.) Therefore, as a future perspective, I would be happy if it were possible to set this to a complete dark mode menu-bar with white text on a black background.
Thanks for your suggestion.
Currently, Soundop uses the system's default menu. Due to system limitations, customizing the menubar to achieve a specific look is challenging. However, we will keep your suggestion in mind if we redesign the menu in the future.
Best regards,
