Ctrl + Tab to switch projects, Shift + Tab to change active window
#1
Ctrl + Tab is used to switch between all opened projects.
Shift + Tab is used to switch between windows if working on more than one window.
When switching between projects, a window lists all projects will be opened, and you can change selection with the keyboard or select the target project by double-clicking it in the window.
