Batch processing files now supported
#1
Batch processing is helpful to do routine works on a group of files. With the batch processor of Soundop, you can set the processing steps with a processor, set the target format, and set the location and file name to save the new files.
Several files can be processed concurrently to use the power of your multi-core CPU. You can cancel running for some files and add new files for processing in the process of batch processing.
