03-16-2025, 09:22 AM
(This post was last modified: 03-17-2025, 01:46 AM by balanced.)
Thank you, much appreciated. I will make backups and continue using the software to see if everything works from now on.
Edit: It seems that the same behaviour didn't happen again for me and it's working now, I will continue using workspaces with backups.
03-26-2025, 02:19 AM
(This post was last modified: 03-26-2025, 02:20 AM by balanced.)
Couple of observations:
It seems that toolbar icon settings are not saved to workspaces? I believe I adjusted them to my liking last time I customized my workspaces, hiding all unnecessary icons. Now pretty much all icons are present again in the toolbar. I think I upgraded the software in between, I might not have noticed that all icons are back again when I did the upgrade.
And another one, resetting level indicators does not work in track meters or the Levels panel if you use static peaks.
03-26-2025, 02:43 AM
(This post was last modified: 03-26-2025, 02:44 AM by balanced.)
Another one still:
I tried to start recording sample material for my new piece today. I'm working in Audio File editor but I can't seem to find a way to monitor the signal being recorded. I can meter the signal and play back the recorder file, but I see no way to listen to incoming signal. Is this really the case or am I missing something obvious? In mixspace mode there is button for every track to easily enable or disable input monitoring.
For simple recording tasks you need the input monitoring button to be available, as messing with your sound card direct monitoring settings is not always convenient. Also if you want to use input FX for recording in Audio File editor, I can't see how you would be able to hear what you are doing, if you can't monitor the input. But perhaps I'm missing something here? I consulted the manual but couldn't find advice there.
(03-26-2025, 02:19 AM)balanced Wrote: Couple of observations:
We have supported saving tool button visible states to workspaces in the latest version. The problem of the level indicator was also fixed. Please check it out.
(03-14-2025, 12:05 AM)Dmitry Wrote: (03-13-2025, 07:40 PM)ivosight Wrote: (03-13-2025, 04:13 AM)Dmitry Wrote: Good day!
When you right-click on the ‘Video’ panel, the ‘Export Video’ option becomes available.
This is a very useful function. Is it possible to customise export parameters?
Thank you for your suggestion. Which parameters would you like to customize?
I would like to be able to keep the original bitrate of the video, or change the bitrate.
And most importantly - the ability to select bitrate and other audio parameters.
We have supported setting audio and video bitrates when exporting video in the latest version. Please check it out.
(03-26-2025, 02:43 AM)balanced Wrote: Another one still:
We have supported monitoring input in the audio file editor in the latest version. Please check it out.
Thank you for these
I tested the Monitor input feature briefly. Would it be possible to enable the monitoring to work also when pause & rec are both engaged? And to enable this state to be achieved by pressing first pause and then rec? The problem now is that you can't hear what you are about to record (before recording) if you route audio through Soundop.
Threads: 2
(04-21-2025, 02:57 AM)ivosight Wrote: (03-14-2025, 12:05 AM)Dmitry Wrote: (03-13-2025, 07:40 PM)ivosight Wrote: (03-13-2025, 04:13 AM)Dmitry Wrote: Good day!
Thank you so much!
(04-22-2025, 06:21 AM)balanced Wrote: I tested the Monitor input feature briefly. Would it be possible to enable the monitoring to work also when pause & rec are both engaged? And to enable this state to be achieved by pressing first pause and then rec? The problem now is that you can't hear what you are about to record (before recording) if you route audio through Soundop.
Thanks for your suggestion.
We have released a new version that supports monitoring input signals in the audio file editor while recording is paused. Please check it out.
