Threads: 12
I know that the bits can be modified when saving the audio, but when processing a lot of audio at the same time, I still hope that the engineer can add the bit depth option.
audition
soundop
Threads: 60
(01-21-2022, 06:56 PM)18216239004 Wrote: I know that the bits can be modified when saving the audio, but when processing a lot of audio at the same time, I still hope that the engineer can add the bit depth option.
audition
soundop
If we add the bit depth when converting sample type, there will be some problems because Soundop will do dithering when converting to lower bit depth. And it's not desirable to do dithering more than once.
Threads: 60
We have re-investigated the problem of bit depth. It seems more manageable to add the bit depth property to audio files.
The latest version of Soundop has added bit depth property. Please check it out.
