Align track to beats with shift of ruler - Printable Version +- Ivosight Forums (https://ivosight.com/forums) +-- Forum: Audio Software (https://ivosight.com/forums/forumdisplay.php?fid=1) +--- Forum: Soundop (https://ivosight.com/forums/forumdisplay.php?fid=3) +--- Thread: Align track to beats with shift of ruler (/showthread.php?tid=523) |
Align track to beats with shift of ruler - jroback - 03-29-2025 I have a clip in the audio editor and I want to align the beats to the editor so I can count forward and back by beats. I have the ruler set to Beats. I'm able to use the selection grid (which is really cool!) to drag out four beats. I've also seen how I can use the left mouse down to increase and decrease the Tempo which does slide the ruler.... but I still can't align it so I can't get the correct temp either. I've uploaded a picture to show how far I got so far (#1 and #2) The workflow I was hoping for was: 1) Drag out a selection grid of exactly 1 bar. 2) Slide the ruler to move the ruler's first bar of a measure to the beginning of my selection. (705.1 in this example). 3) Anchor the ruler so that it won't move when I drag the tempo indicator. 4) Drag the tempo up and down until the 4 beats (705.1->706.1) align with my selection. At this point, as long as the song is consistent I should be able to easily identify the beats. is this possible? I've tried various combinations but not been able to do this. Thanks! By the way, loving the software so much! I just purchased the Perpetual License. RE: Align track to beats with shift of ruler - ivosight - 04-02-2025 (03-29-2025, 02:33 PM)jroback Wrote: I have a clip in the audio editor and I want to align the beats to the editor so I can count forward and back by beats. I have the ruler set to Beats. I'm able to use the selection grid (which is really cool!) to drag out four beats. I've also seen how I can use the left mouse down to increase and decrease the Tempo which does slide the ruler.... but I still can't align it so I can't get the correct temp either. I've uploaded a picture to show how far I got so far (#1 and #2) Hi, Thank you for purchasing our software. Currently, Soundop does not support shifting the time ruler. However, you can align the beats if your time selection starts from the beginning. One possible workaround is to delete the audio that falls before the measure range, and then use the undo function to restore it after measuring the tempo. Welcome your further suggestions. Best regards, RE: Align track to beats with shift of ruler - jroback - 04-11-2025 (04-02-2025, 07:11 AM)ivosight Wrote:That will work great, thanks for the idea!(03-29-2025, 02:33 PM)jroback Wrote: I have a clip in the audio editor and I want to align the beats to the editor so I can count forward and back by beats. I have the ruler set to Beats. I'm able to use the selection grid (which is really cool!) to drag out four beats. I've also seen how I can use the left mouse down to increase and decrease the Tempo which does slide the ruler.... but I still can't align it so I can't get the correct temp either. I've uploaded a picture to show how far I got so far (#1 and #2) RE: Align track to beats with shift of ruler - jroback - 05-15-2025 (04-11-2025, 01:54 PM)jroback Wrote:(04-02-2025, 07:11 AM)ivosight Wrote:(03-29-2025, 02:33 PM)jroback Wrote: I have a clip in the audio editor and I want to align the beats to the editor so I can count forward and back by beats. I have the ruler set to Beats. I'm able to use the selection grid (which is really cool!) to drag out four beats. I've also seen how I can use the left mouse down to increase and decrease the Tempo which does slide the ruler.... but I still can't align it so I can't get the correct temp either. I've uploaded a picture to show how far I got so far (#1 and #2) So in thinking about this more, this actually doesn't work, because it's not that I want to measure the BPM, it's that I want the beat grid to be aligned to my audio file. However, I noticed in the Mixspace view, I can move the clip forward and backwards very easily, which allows me to align my clip right to the beat grid. Have you considered adding the functionality to move a clip forward and backwards inside of the Audio File editng view? This would help a lot. RE: Align track to beats with shift of ruler - ivosight - 05-16-2025 (05-15-2025, 05:47 PM)jroback Wrote:(04-11-2025, 01:54 PM)jroback Wrote:(04-02-2025, 07:11 AM)ivosight Wrote:(03-29-2025, 02:33 PM)jroback Wrote: I have a clip in the audio editor and I want to align the beats to the editor so I can count forward and back by beats. I have the ruler set to Beats. I'm able to use the selection grid (which is really cool!) to drag out four beats. I've also seen how I can use the left mouse down to increase and decrease the Tempo which does slide the ruler.... but I still can't align it so I can't get the correct temp either. I've uploaded a picture to show how far I got so far (#1 and #2) Hi, There are no clips in the audio file editor. You might consider inserting silence at the beginning of the audio file to align the beats with the grid. Best regards. |
