Remix your MUSIC to be any length! pls - Printable Version +- Ivosight Forums (https://ivosight.com/forums) +-- Forum: Audio Software (https://ivosight.com/forums/forumdisplay.php?fid=1) +--- Forum: Soundop (https://ivosight.com/forums/forumdisplay.php?fid=3) +--- Thread: Remix your MUSIC to be any length! pls (/showthread.php?tid=475) |
Remix your MUSIC to be any length! pls - pavelgazi - 09-10-2024 Sometimes i need an exact size piece of audio to fill in a gap in my podcast or video but the clip you have is not long enough. thanks. RE: Remix your MUSIC to be any length! pls - ivosight - 09-15-2024 (09-10-2024, 08:19 PM)pavelgazi Wrote: Sometimes i need an exact size piece of audio to fill in a gap in my podcast or video but the clip you have is not long enough. thanks. Hi, You can export time selection in the multi-track editor. Best regards. RE: Remix your MUSIC to be any length! pls - Riola - 09-19-2024 If you’re looking to remix audio for your podcast, I’ve had good luck with Audacity. It’s pretty straightforward—just import your clip and use the "Time Stretch" effect to adjust the length. Sometimes I’ll loop a part or fade in and out to make it fit perfectly. |
