Export Audio - Printable Version +- Ivosight Forums (https://ivosight.com/forums) +-- Forum: Audio Software (https://ivosight.com/forums/forumdisplay.php?fid=1) +--- Forum: Soundop (https://ivosight.com/forums/forumdisplay.php?fid=3) +--- Thread: Export Audio (/showthread.php?tid=333) |
Export Audio - GuuZ7 - 12-15-2020 When I export an audio selection, ther is a two bar silence in the beginning, why is that!? RE: Export Audio - ivosight - 12-17-2020 (12-15-2020, 03:54 AM)GuuZ7 Wrote: When I export an audio selection, ther is a two bar silence in the beginning, why is that!? Hi, We can not reproduce the problem. Are you using the latest version? And Can you give more details about the steps and format when saving the audio file? Thanks. Best regards. RE: Export Audio - GuuZ7 - 12-18-2020 I load an audiofile (wav), select all and export selection. After that I load the saved selection, that's all! RE: Export Audio - ivosight - 12-18-2020 (12-18-2020, 01:19 AM)GuuZ7 Wrote: I load an audiofile (wav), select all and export selection. Hi, It seems your software works in demo mode. The demo version will mute 500 ms every 15 seconds. Best regards. |
