Set a precise value for an envelope point - Printable Version +- Ivosight Forums (https://ivosight.com/forums) +-- Forum: Audio Software (https://ivosight.com/forums/forumdisplay.php?fid=1) +--- Forum: Soundop (https://ivosight.com/forums/forumdisplay.php?fid=3) +--- Thread: Set a precise value for an envelope point (/showthread.php?tid=176) |
Set a precise value for an envelope point - ivosight - 11-26-2018 Sometimes you may wish to set a precise value for an envelope point, but by dragging the point may not easy to achieve the desired result. Now you can edit the envelope value in a dialog, by input the digits for value. There may be limitations for some plug-ins because the custom text-to-number conversion was not supported, you will have to input a number between 0 ~ 1 to set the value. |
