some feature suggestions - Printable Version +- Ivosight Forums (https://ivosight.com/forums) +-- Forum: Audio Software (https://ivosight.com/forums/forumdisplay.php?fid=1) +--- Forum: Soundop (https://ivosight.com/forums/forumdisplay.php?fid=3) +--- Thread: some feature suggestions (/showthread.php?tid=364) |
RE: some feature suggestions - ivosight - 12-19-2024 (12-18-2024, 08:37 AM)balanced Wrote: Thank You for Your kind words Hi, Soundop has a Projects panel to list and switch between opened files. You can also drop files into the panel to open them. Best regards. RE: some feature suggestions - ivosight - 12-19-2024 (12-18-2024, 08:44 AM)balanced Wrote: And another one concerning peak files: Hi, Thanks for the suggestion. We will consider adding it in future versions. Best regards. RE: some feature suggestions - ivosight - 12-19-2024 (12-18-2024, 09:34 AM)balanced Wrote: Another suggestion concerning plugin management and using the "sort by location" option: Hi, It seems Reaper does not support organizing plugins according to physical location. Could you give more details? Thanks. Best regards. RE: some feature suggestions - balanced - 12-20-2024 (12-19-2024, 08:03 AM)ivosight Wrote: Hi, Hi, I'm running the latest version, but I have always had my plugins organized by physical location in Reaper. I will have to see if there is an option for this to work, but I have my plugin folders listed in VST paths and they merge together nicely using the physical folder structures I have created in Windows Explorer. RE: some feature suggestions - balanced - 12-20-2024 For the Reaper plugin management reference: right click All plugins / Show in left pane list / VST folders RE: some feature suggestions - ivosight - 12-21-2024 (12-20-2024, 02:08 AM)balanced Wrote: For the Reaper plugin management reference: right click All plugins / Show in left pane list / VST folders Thank you very much for the elaboration. We have found it now.
RE: some feature suggestions - balanced - 12-28-2024 You're welcome, have a happy holiday! I got another small feature request: Add an option to preferences / effects or "manage VST plugins" window to automatically scan for new plugins when opening Soundop. This is either standard behavior or an option for many DAWs as far as I understand. You would got to have a failsafe mechanism though for the odd situation when a plugin makes Soundop crash while scanning, so you would not end up always crashing the software before it even opens. Cheers, A RE: some feature suggestions - balanced - 12-28-2024 And another one: I wonder if the "play effect tail when stop playback" could be extended to audio file editing too? Or make another checkbox option for that too, if you prefer. One could asses time based fx processing easier this way for single files too. Btw, as the amount of selectable options grow in preferences, it would be great to have an search box for text items in options menu. Reaper does have a simple implementation of this. It obviously does have a lot more options to cover, but I have found this to be an easy method for quickly checking if a program has an option for a specific thing, before I start to browse through the preferences pages and read options one by one. Cheers Cheers RE: some feature suggestions - ivosight - 01-02-2025 (12-28-2024, 09:06 PM)balanced Wrote: You're welcome, have a happy holiday! Hi, Thanks for the suggestion. We will consider adding it. Best regards. RE: some feature suggestions - ivosight - 01-02-2025 (12-28-2024, 09:33 PM)balanced Wrote: And another one: I wonder if the "play effect tail when stop playback" could be extended to audio file editing too? Or make another checkbox option for that too, if you prefer. One could asses time based fx processing easier this way for single files too. Hi, Thanks for the suggestions. We will consider implementing them. Best regards. |
