Hello, I am having some issues, after selecting an audio region and enabling “Use current selection for processing”, the processor returns an empty file or only processes a small portion. I find that if I run another processor first, then undo and run the original processor again, it works fine — as if there is an internal cache error.
Also, I am having a lot of issues with VST3 plugins, especially FabFilter Pro-Q 3. An EQ band does not work even though it is enabled.
Some presets are stuck or the plugin does not respond properly after reopening the project.
I have not found a way to reproduce the bug consistently, but these bugs happen frequently when working a lot with multitrack.
Thanks
(05-08-2025, 06:21 PM)amosfuegel Wrote: [ -> ]Hello, I am having some issues, after selecting an audio region and enabling “Use current selection for processing”, the processor returns an empty file or only processes a small portion. I find that if I run another processor first, then undo and run the original processor again, it works fine — as if there is an internal cache error.
Thanks
Thanks for reaching out.
We are unable to reproduce the bugs you reported. Could you give more details on how to reproduce the bug?
Thank you.
The bug is like this: After installing FabFilter Pro-Q 3, everything seems to work fine, but sometimes it doesn't work in the log in state. After exporting, it appears that the plugin state is not applied there. I've had this happen a few times.
(05-09-2025, 10:27 PM)pavelgazi Wrote: [ -> ]The bug is like this: After installing FabFilter Pro-Q 3, everything seems to work fine, but sometimes it doesn't work in the log in state. After exporting, it appears that the plugin state is not applied there. I've had this happen a few times.
Soundop processes consistently and does not change over time. This issue is likely related to the plugin itself. Please reach out to FabFilter to determine the cause of the problem.
Thank you.
