01-12-2023, 08:55 PM
I'm not exactly sure what's causing this, but occasionally when I run a processor it doesn't work correctly.
Sometimes it will return an empty audio file. Other times it will only process a part of the sound, despite the entire sound being selected. (And yes I have "Use Current Selection for Processing" enabled).
I've found that when I encounter this bug, if I run a different processor, undo, and then run the original processor I wanted, it will work. You can see this behavior in the video I posted.
Also, there are some bugs with various VST3 plugins that I've been using - but I can't figure out how to reliably reproduce the problems.
As an example, I use FabFilter Pro-Q 3 heavily. It's my go-to EQ. But sometimes it bugs out in Soundop in very strange ways.
For instance, sometimes, an EQ band won't work. Sometimes when I enable the dynamic EQ feature and then switch to a non-dynamic preset, it still "thinks" the band is dynamic and malfunctions. I'm sorry I can't give more information than this. I will make a separate post when I figure out how to reliably reproduce this bug.
Thanks for taking a look.
