04-12-2020, 08:11 AM
(04-12-2020, 07:40 AM)rotong Wrote: [ -> ]Hi there,
After the update still no active CD Burner in CD Project. The device is only visible to extract from CD. Sorry!
Regards.
Can you extract tracks from that CD burner?
Regards.
(04-12-2020, 08:26 AM)rotong Wrote: [ -> ]Perhaps I'm saying something stupid but besides my job as a teacher in computer technology I've also been a system programmer myself, although in the far past, so I know a little from programming structures. In the meantime a lot has been changed regarding programming and languages though! I know that...
I've seen in a process monitor tool, monitoring Soundop, that this registry key is being consulted too:
HKEY_CURRENT_USER\SOFTWARE\Ivosight\Soundop\Settings\CD Burning\Active Device
Could it be that there has to remain a value inside of this key to indicate the active CDROM burn device?
Just thinking!
(04-12-2020, 09:01 AM)ivosight Wrote: [ -> ]That would be great!(04-12-2020, 08:26 AM)rotong Wrote: [ -> ]Perhaps I'm saying something stupid but besides my job as a teacher in computer technology I've also been a system programmer myself, although in the far past, so I know a little from programming structures. In the meantime a lot has been changed regarding programming and languages though! I know that...
Just thinking!
Soundop requires the Write privilege when creating the CD-burning device; that's the only difference from creating devices for extracting audio tracks. If you can extract tracks from the CD driver, we can make some modifications to ignore the Write privilege and check if burning can still be successful.
(04-13-2020, 02:38 AM)rotong Wrote: [ -> ](04-12-2020, 09:01 AM)ivosight Wrote: [ -> ]That would be great!(04-12-2020, 08:26 AM)rotong Wrote: [ -> ]Perhaps I'm saying something stupid but besides my job as a teacher in computer technology I've also been a system programmer myself, although in the far past, so I know a little from programming structures. In the meantime a lot has been changed regarding programming and languages though! I know that...
Just thinking!
(04-13-2020, 05:57 AM)rotong Wrote: [ -> ]Hi there,
Just tested this version. If I push the button "Burn to CD" I get the following message:
get mode parameter failed
No drive appears in the Burn Audio CD dialog!
Regards!
Regards!
(04-13-2020, 07:45 PM)ivosight Wrote: [ -> ](04-13-2020, 05:57 AM)rotong Wrote: [ -> ]Hi there,
Regards!
It seems your CD driver only working with ASPI (Advanced SCSI Programming Interface) and does not support SPTI (SCSI Pass Through Interface), and we are not going to write a drive to support ASPI as Nero.
Sorry about that.
(04-14-2020, 01:47 AM)rotong Wrote: [ -> ](04-13-2020, 07:45 PM)ivosight Wrote: [ -> ](04-13-2020, 05:57 AM)rotong Wrote: [ -> ]Hi there,
Regards!
Sorry about that.
You mean to get it work I should buy another CD/DVD Drive?
