Announcements
Threads
- Feature request: Ability to select left or right channel only and apply processing (12 Replies)
- Some suggestions for the next updates. (17 Replies)
- 2 bugs and 1 feature request (5 Replies)
- In multitrack mode, mute button has no effect (1 Reply)
- Request: Double Click to select between markers (3 Replies)
- After the wav file is processed, there is noise when saving and then opening it (1 Reply)
- Larger Icons (5 Replies)
- Silence shortener starts working slower and slower over the course of processing (3 Replies)
- Sample rate issue with "save as" option (3 Replies)
- Some suggestions for audio Markers function (10 Replies)
- I hope engineers can add the option of bit depth. (2 Replies)
- Horizontal scroll bar design is not easy to use (2 Replies)
- vst plugin is missing (5 Replies)
- Problems and suggestions encountered in the trial soundop (11 Replies)
- Sampling rate display problem in G+audio (3 Replies)
- Problem with looping wav file (audio loop) (6 Replies)
- Soundop audio sample rate problem (3 Replies)
- About the problems in the use of soundop1.8.6.3 (3 Replies)
- Feature request:purge files in mixspace (2 Replies)
- Record time (3 Replies)
